edit path of oneagent tools folder
Hi, in this article: Host group reconfiguration is now easier than ever | Dynatrace news
you want to change: C:\Program Files (x86)\dynatrace\oneagent\agent\tools
into
“C:\Program Files\dynatrace\oneagent\agent\tools”
as these files are no longer installed into the x86 folder since you upgrade OA to be fully x64
Davide
Thank you so much, @DavidePiras, for the catch!
The blog article was updated, and the path in it to the oneagentctl is now correct.
