I have an EF1 extension that I’m trying to migrate to EF2. It has a dependency on paramiko. If I include it into setup.py, what I should, the error below appears. Why?
"error": [
"[notice] A new release of pip is available: 24.1.1 -> 24.2",
"[notice] To update, run: python.exe -m pip install --upgrade pip",
"ERROR: Cannot install extensionA because these package versions have conflicting dependencies.",
"ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts",
"Traceback (most recent call last):",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\runpy.py\", line 196, in _run_module_as_main",
" return _run_code(code, main_globals, None,",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\runpy.py\", line 86, in _run_code",
" exec(code, run_globals)",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\Scripts\\dt-sdk.exe\\__main__.py\", line 7, in <module>",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\typer\\main.py\", line 326, in __call__",
" raise e",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\typer\\main.py\", line 309, in __call__",
" return get_command(self)(*args, **kwargs)",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\click\\core.py\", line 1157, in __call__",
" return self.main(*args, **kwargs)",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\typer\\core.py\", line 723, in main",
" return _main(",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\typer\\core.py\", line 193, in _main",
" rv = self.invoke(ctx)",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\click\\core.py\", line 1688, in invoke",
" return _process_result(sub_ctx.command.invoke(sub_ctx))",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\click\\core.py\", line 1434, in invoke",
" return ctx.invoke(self.callback, **ctx.params)",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\click\\core.py\", line 783, in invoke",
" return __callback(*args, **kwargs)",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\typer\\main.py\", line 692, in wrapper",
" return callback(**use_params)",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\dynatrace_extension\\cli\\main.py\", line 114, in build",
" wheel(extension_dir, extra_platforms, extra_index_url, find_links)",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\dynatrace_extension\\cli\\main.py\", line 227, in wheel",
" run_process(command, cwd=extension_dir)",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\site-packages\\dynatrace_extension\\cli\\main.py\", line 410, in run_process",
" return subprocess.run(command, cwd=cwd, env=env, check=True) # noqa: S603",
" File \"C:\\Users\\vboxuser\\AppData\\Local\\Programs\\Python\\Python310\\lib\\subprocess.py\", line 526, in run",
" raise CalledProcessError(retcode, process.args,",
"subprocess.CalledProcessError: Command '['C:\\\\Users\\\\vboxuser\\\\AppData\\\\Local\\\\Programs\\\\Python\\\\Python310\\\\python.exe', '-m', 'pip', 'download', '-d', 'extension/lib', '--only-binary=:all:', '--platform', 'linux_x86_64', '.']' returned non-zero exit status 1.",
"detailedOutput": [
