Efficient way for IBM MQ Monitoring
As per the documentation published in 2019, “What is Message queue?” it’s mentioned that
" For IBM MQ, Dynatrace doesn’t place trace tags on messages so as to avoid issues with older mainframe programs. Nevertheless, we’re able to trace messages across IBM MQ. If you have transactions that jump queues or queue manager boundaries, Dynatrace can’t connect the transactions automatically. To support such use cases, we will soon provide a new API."
Kindly advise , how can we monitor IBM-MQ efficiently as in our case transitions that goes through multiple queues and beyond the boundaries of the queue. If any latest documentation available, please share.
If you install the IBM MQ extension to the queue managers we automatically detect all cluster queues and alias queues and such and use that information to connect the traces.
