Elasticsearch problem
I always get the message “Elasticsearch Problem” after adding new nodes to the current cluster. The problem disappears after about 72h-96h. This is probably due to data synchronization.
How can I check what DT is doing during this time? Alternatively, how can I check the proges?
Radek
Hello Radek,
Maybe this doc will help to check the ealsticseach status.
curl -X GET "localhost:9200/_cluster/health
Cheers!
RN
Hi @RazTN7
Ok, I thought it could be checked from DT logs etc. Thanks for the reply - I’ll give it a try after adding another node today on my environment.
Thank you!
Radek
Thanks for the hint! I got all the information I was interested in :slightly_smiling_face:
