Do you have any dashboards where the filters used in ELK can also be applied in Dynatrace? I’d like to recreate an existing ELK dashboard in Dynatrace. If anyone has a sample dashboard or can share one, I’d really appreciate it. Thanks!
Do you have an example?
Best regards
