Enable/Disable OneAgent features at host/host-group level
Hello.
I am interested to test some OneAgent features on specific hosts, but the only option is to do it at process-group level:
But the hosts we would like to test are a subset of the hosts of process groups. Is there a way to do this at a host/host-level?
Thank you.
Unfortunately, I do not see any way you could configure this at the host level instead of the process group / global level. One thing you could try doing is creating process group detection rules to create a process group of only the hosts you want to test the feature on, but that may be more of a hassle than it’s worth.
Yes Diniel, that was my guess too. It seems strange though not to have such an option.
I’m facing the same problem to not being able to enable OneAgent features as host/HG level.
@Theodore_x86 @danielD you can vote this RFE :
https://community.dynatrace.com/t5/Product-ideas/OneAgent-features-Configuration-on-Host-Group-Level-or/idi-p/227383
