Each released version comes with Standard 9 months support.
Recommended:
1. Active gate:
Auto-update enabled. Update ActiveGate — Dynatrace Docs
2. One Agent:
Auto-update enabled. OneAgent update — Dynatrace Docs
Define One agent updates window. OneAgent update — Dynatrace Docs
3. RUM Javascript:
You can choose between latest stable version or Previous stable version. Go to Settings classic → Web and Mobile monitoring → RUM JavaScript updates
Other options:
1. One Agent:
If global update doesn’t work well for few hosts/teams, you can also configure this on a host group or host level. OneAgent update — Dynatrace Docs
2. Active gate:
You can plan and do a one-click update.
3. Manual updates is also an option.
It is recommended, post every update check for any anomalies and reach out to support team if any issues with the latest version.
