Encrypt SSL certificate failed to refresh on node
My DT managed clusters shows this message:
Let’s Encrypt ssl certificate failed to refresh on node,
What to do?
KR Henk
Henk, we’ll be happy to help you. Due to the private and secure nature of managing SSL Certificates, please contact with our support team and we’ll continue together with your specific case.
Hi @henk s.: in our case, restarting nginx made the certificate refresh:
Log on to your Dynatrace server. Then go to the installation folder (default is /opt/dynatrace-managed/). Then go to launcher directory.
Then restart nginx on each node, using ./nginx.sh restart
That’s a workaround for the issue we had recently. Henk had a different issue back then 2 years ago :slightly_smiling_face: Thx for posting the feedback!
