End of support announcements for technologies, platforms, and components
Hello All,
You often ask about the end of support for a given version of the OneAgent or monitored technologies. Thanks to your feedback, we list all that information in the Dynatrace Help now.
  • See Dynatrace release notes to check how long Dynatrace versions are supported following rollout.
  • See the End of support announcements for the OneAgent versions that are the first versions to no longer support the listed technologies, platforms, and components.
Best regards,
Karolina
Thank you @Karolina_Linda for the links! Also here are the currently supported technologies: Technology support — Dynatrace Docs
