Enforce DQL query requirements
Is there a way in the platform where I can enforce that a query MUST contain the “bucket” parameter. For example, I want all non-admin users to utilize buckets and if they don’t they will not see any data. ie:
will show results:
fetch logs, bucket:{“my-service_logs”}
will NOT show results:
fetch logs
The end goal is to get people to utilize buckets to optimize queries
@calfanonerey You can configure IAM policy permissions to limit user access to specific buckets , so they would only see the data from the buckets they have permissions to view.
Thanks! But if I have a user with the assigned buckets and they do a fetch logs command they will just see the data for all the buckets they have access to right? Ideally I would want them to use the buckets parameter otherwise they should not see any data
@calfanonerey Right, they would see all buckets they have access to, not sure there is a way currently to enforce a rule at DQL query level.
This is an interesting option to have , you can open a idea and see if it gets through
For now, I think educating the end-users on the DQL best practices is the option (I know its not easy)
