Enrich logs with OneAgent metadata when sending via FluentBit
I am looking to send all my logs via FluentBit and need to export them to multiple destination with Dynatrace being one of them as well as to a SIEM and a long term cold storage on Azure Blob Storage. FluentBit looks like the right tool for the job, however I am at a loss as to how I should proceed to enrich my logs with OneAgent specific metadata (see Enrich ingested data with Dynatrace-specific dimensions - Dynatrace Docs). Note that I am not on Kubernetes and cannot use the new Dynatrace Operator to do so (see https://www.youtube.com/live/r2g-Vs8n6So?si=PmmJduwyovVS-ipi).
Would anyone of you from the community know how I should go about to enrich my logs so as to not miss any OneAgent metadata or dimensions?
Note, if there is a way I can use a OneAgent to send my logs to multiple destinations, I am not against using that instead of FluentBit, just let me know how :wink:
Thanks for your help.
