it appears that you have duplicate rules. This happens if there is an application with the same rule present. For example, I have an application called “EasyTravel” that is defined as URL Begins with: Easytravel.
But if I create another rule for a new application called EasyTravel1 and define it with URL Begins with: Easytravel. it will error out as the values are the same and there is a conflict.
Hi @Chad I am using monaco so once I deploy the rule than every time i need to either remove the configuration from repository or need to add skip deployment tag
