Error handling for DQL query client
I fetch data via DQL using the queryExecutionClient from @dynatrace-sdk/client-query and I want to handle errors correctly. I know that there is the ErrorResponseDetails, but I don’t know how to extract it.
import {
  queryExecutionClient,
  QueryResult,
} from '@dynatrace-sdk/client-query';
        .queryExecute({
          body: {
            query,
            requestTimeoutMilliseconds: 30000,
          abortSignal,
        .then((response) => {
          setResult(response.result);
          setError(undefined);
        .catch((error) => {
          // How can I get the ErrorResponseDetails
        .finally(() => {
          setLoading(false);
Hi s_eilmsteiner,
You could try using the util function “isClientRequestError” with the desired type of error or “isErrorEnvelopeError”.  It depends on the expected error.
<span>import</span><span> { </span><span>queryExecutionClient</span><span>, ErrorResponseDetails</span><span>, </span><span>isClientRequestError</span><span>, </span><span>isErrorEnvelopeError</span><span> } </span><span>from</span> <span>'@dynatrace-sdk/client-query'</span><span>;</span><br><br><span>await</span> <span>queryExecutionClient</span><span>.</span><span>queryExecute</span><span>({ ...</span><span> }).</span><span>catch</span><span>((</span><span>e</span><span>) </span><span>=></span><span> {</span><br><span>  </span><span>if</span><span> (</span><span>isClientRequestError</span><span><ErrorResponseDetails</span><span>>(</span><span>e</span><span>)) {</span><br><span>    </span><span>console</span><span>.</span><span>error</span><span>(</span><span>'ErrorResponseDetails', e</span><span>);</span><br><span>  }</span><br><span>  </span><span>// OR</span><br><span>  </span><span>if</span><span> (</span><span>isErrorEnvelopeError</span><span>(</span><span>e</span><span>)) {</span><br><span>    </span><span>console</span><span>.</span><span>error</span><span>(</span><span>'EnvelopeError', e</span><span>);</span><br><span>  }</span><br><span>});</span>
