After successful connection to AWS by Role-based authentication I cannot add Amazon CloudWatch Logs Service. When I’m trying to do so this pop up comes out:
As you can see Amazon Cloudwatch Logs is non default so you must install and configure an Environment ActiveGate if you want to monitor either or both of the following:
More than 2,000 AWS resources (AWS service instances)
Go to Stacks and create a new stack with new resources.
Select Template is ready, upload the template you created above, and select Next.
In Parameters, enter External ID, ActiveGateRoleName and ActiveGateAccountID from the stack created in Step 2.3.2.1. Optionally, adapt other parameters if needed.
Enter a name for your stack, and then select Next twice.
Review your configuration, enable I acknowledge that AWS CloudFormation might create IAM resources with custom names, and select Submit.
