When I try to install in docker I get this error:
11:00:13 Started agent deployment as a Docker container, PID 27637.<br>11:00:13 Downloading agent to /tmp/Dynatrace-OneAgent-Linux.sh via https://xxxxxx.live.dynatrace.com/api/v1/deployment/installer/agent/unix/default/latest?Api-Token=***&arch=x86&flavor=default<br>11:00:14 Download was skipped as the agent version did not change<br>11:00:14 Validating downloaded agent installer<br>11:00:15 Verification successful<br>11:00:15 Deploying to: /mnt/host_root<br>11:00:15 Starting installer...<br>11:00:18 Checking root privileges...<br>11:00:18 OK<br>11:00:18 Installation started, version 1.149.188.114613, build date: 31.07.2018, PID 27637.<br>11:00:18 Detected platform: LINUX arch: X86<br>11:00:18 Detected bitness: 64<br>11:00:18 Filesystem with /opt/dynatrace/oneagent is mounted under /opt<br>11:00:18 Error: Free space on filesystem with /opt/dynatrace/oneagent: 887 MiB<br>11:00:18 Error: Not enough space on /opt/dynatrace/oneagent. Required free space: 1000 MiB
