My end encountered error below when trying to trigger workflow:
Error: Forbidden
Error Description: IAM policy condition does not match
Upon checking on the authorization setting, seems like my role doesn’t have sufficient permission to modify it:
Attached the policy assigned to my account, perhaps there is any rule related to workflow missing out that I am not aware off?
Thanks in advance for the reply.
Teh
App Engine Admin Policy Rule.txt (2.25 KB)
I think you miss:
‘automation:workflows:run’
‘automation:workflows:write’
Could you please open developer tools in your browser and go to the “Authorization Settings” view and show the response to the
platform/iam/repo/environment/<tenant>/bindings/...
For me, it looks like you’re missing “iam:bindings:*” permissions.
Hi s_eilmsteiner,
Thanks for your response.
Had added both rule under policy but no luck.
Teh
Hi Michal,
Not sure if I get you correctly, but I didn’t see any here:
Didn’t see authorization setting available.
And yeap, still having this error message:
I believe it is something to with the policy rule.
Wondering if there is any documentation that I can refer to sort out the missing rules?
Thanks.
Teh
Hi Teh,
We have found a missing piece on our side (an internal policy binding was not there). Now, you should be able to run workflows without any problems. Could you please confirm that?
Please also make sure that you consent to at least “Primary Permissions” in the “Authorization Settings” (top right) in the Workflow app.
Hi Michal,
Good news, it is working now!!!
Big thanks.
Teh
