Error while downloading agent on OCP Openshift
Hi All,
We found an error while downloading the agent.
In the ocp console, we found this error in the logs:
05:20:47 Attention! ONEAGENT_INSTALLER_SCRIPT_URL does not match expected pattern, please verify its correctness. See the following help page for instructions how to retrieve the URL: Set up Dynatrace OneAgent as a Docker container — Dynatrace Docs. If installer download succeeded, then this message may safely be ignored
05:20:55 Started agent deployment as a container, PID 2087405.
05:20:55 Downloading agent to /tmp/Dynatrace-OneAgent-Linux.sh via 10.59.99.73:9999/e/b55543e5-242a-4c6b-8aab-4ee1a010c9e0/api/v1/deployment/installer/agent/unix/default/latest?Api-Token=*&arch=x86&flavor=default
05:20:55 Error: Download failed
Also status of the node is CrashLoopBackOff
And this is the condition now:
Any advices on this?
Thank you
Hi zhahir_tajudin,
Are you using Dynatrace SaaS or Managed. Please check your cr.yaml to confirm you are using the proper format in apiUrl parameter.
Moe
