What does it cost to enable event monitoring on k8s, and what are the requirements for cluster nodes
Hi @Lwl :smiling_face_with_sunglasses:
You can find the requirements for starting the K8S event monitoring here:
Licensing of this functionality is based on DDU licences.
From documentation:
To estimate the number of events that consume DDUs, you can query the dsfm:active_gate.kubernetes.events.processed metric, which provides information about the number of events that are being ingested into Dynatrace per Kubernetes cluster.
Example query for a 24-hour timeframe:
dsfm:active_gate.kubernetes.events.processed:splitBy(“dt.entity.kubernetes_cluster”):sum:auto:sort(value(sum,descending)):limit(10)
Radek
