What is backend exception mask (global vs local)
original post: 什么是后端异常掩码(全局与本地)
To configure and finetune exceptions on backend, you can follow the below document
Regarding the masking of sensitive data, you can check the below documents showing the masking levels and how to configure
Islam
thanks very much
This is the problem: Configure data privacy settings — Dynatrace Docs
since it is global - a lot of side effects
We are using as “temprorary” before dev team will do exceptioon clean up
because all things like key requests are brocken
typical request after enabling:
/get_incident_details/Salesforce/<masked>%<masked>/<masked>%<masked>/0/1000/ASC
