josean
December 16, 2021, 11:32am
1
Hi all.
Can I exclude an exception from a node.js request as an error?
The information I have is:
request name:
/api/data/v1/staging/fact/periodical
file that throws the error:
/stmonit/share/micajero360/back-end/node_modules/express/lib/express.js
and the error message:
“(Staging) You are duplicating ENTRY. Error”
Can somebody help me?
thank you in advance
BR
Jose A
Try go to specific nodejs service, edit, then go to error detection, turn on override global error detection settings. then enter your error string into new exception added in “Ignore exceptions” part.
josean
December 16, 2021, 11:54am
3
Thanks for your answer @rastislav_danis
I don’t know which is the pattern class for this field.
Sorry for ignorance
Ok, now i see your issue. Have you tried to enter any string (or your string) into class input box and then your string into 2nd input box ?
josean
December 16, 2021, 3:49pm
7
Thank you very much, @rastislav_danis !!
seems to work…
