Can you please advise, if there is any way to export incoming and outgoing connection data to a host through API.
Thanks & Regards,
Amaresh Anand
Check the fromRelationships and toRelationships within the Response body objects of Monitored entities API - GET entities list for entity type HOST
HTH
Yos
