Export K8S chart data
Hello All,
I want to export chart data like a red square in the picture below. Can I do that? or Can you suggest any way to get the same data and export it, please?
Thank you,
You have to create custom chart based on the same metrics mentioned above, custom chart can be exported then to SVG/XLS/PNG.
Hi Sebastian,
I tried to create a custom chart but I do not see the metrics “Memory total” to choose.
