Export Problem over excel
hello,
Do we’ve a scope to export problems into an excel exactly like we’ve an option for traces?
Hello @munawarhossain1
Use the API to download in the .json form and then import in Excel.
Babar
Babar
Sorry, I was looking for a simple way! It’s tough for everyone into platform to play with API.
Thanks anyways
No, not available.
You can open an REF for it or vote for whose is opening the same.
I had just raised a similar product idea but it had been discarted.
As others users have already told you, you need to use API, or maybe Grail / DQL / Notebooks.
Best regards
Best regards
Dynatrace Services Portal
Add token to Service Tools and Reports>Tokens for your tenant
Observe&Explore>Problems
Export to Excel button
Is that portal available for all customers?
Best regards
services.dynatrace.com…you might as well try. I am not certain.
