Exporting Dynatrace monitors
Is there a way to export the list of monitors from Dynatrace into Excel or some other tool?
Hi @foobar123, yes you can query the API with a filter for Synthetic Test type.
{{baseUrl}}/entities?entitySelector=type(“SYNTHETIC_TEST”)
Have in mind that type for http is HTTP_CHECK
Hello @DanielS , thank you so much for your response. I am fairly new to DT and trying to find my way around.
‘Dynatrace API’ is greyed out for me as I do not have that privilege, is there any other way to export the list?
Please try to access from here:
