Is there an extended network agent in Dynatrace for tracking connection information?
It would be nice to get “netstat” like information. To be clear, I am not asking for network trace functionality.
Any help would be appreciated.
Lou
Lou
Can you expand a bit on the use case? Would it be something like number of ports in listening mode?
I guess what you would see in a netstat -an where you can see incoming connections listering as well as connections and number of connections ESTABLISHED, TIME_WAIT, CLOSE_WAIT to individual external hosts.
Thanks for the details. We currently do not have something like that. It shouldn’t be too hard to either write a OneAgent extension, or write a script that pipes it into the OneAgent metric ingest on a regular schedule. OneAgent metric API — Dynatrace Docs
If you don’t have the resources yourself you can also contact a Dynatrace partner or the Dynatrace services team to help you out.
Thank you. I have written custom metrics, so I will go that route.
