Hi community,
I’m having trouble configuring the Dynatrace Filesystem Monitoring extension for one of the profiles. Below is the current configuration I’ve set up:
Check settings
- Check type: Modification age
- Path: (censor)
- File system: Local
- Run as: (account censor)
- Frequency: 60 minutes
- Use newest file: Enabled
- Days enabled: All days
- Schedule time: 06:00
- Schedule duration: 30 minutes
The extension is supposed to return the most recent file modification time (with “Use newest file” enabled). However, I’m not getting the expected results or behavior, and I’m unsure if the path, credentials, or other settings are causing the issue.
Despite this configuration, I’ve encountered the following issues:
- In the Data Explorer, under the metric file age, I’m getting a result of -1. From what I’ve read, this might be related to permission issues. However, as mentioned above, the (account censor) account should have the correct permissions to access the specified files.
- I haven’t received any new data after three days of the configuration, even though the schedule and frequency appear to be configured correctly.
- There’s a slider for Enable Debug, but I’m unclear on how to use it or where to locate the debug information after enabling it.
Could you help me understand why I might be seeing these issues and provide guidance on how to proceed, especially with using the debug feature?
