Extension for Aviatrix Network Insights
@AurelienGravier it did work with OpenMetrics which was good as I did not have to add Prometheus :slightly_smiling_face:
I need now to find some spare hours to look through the docs and get an understanding about the various other elements: Topology, Scenes and what is different vs self made Dashboards (which indeed have no parent-child relations and are just showing values).
Any good link up your sleeve that groups all info together and goes through each?
I did find separate articles but at some point ended up with too many tabs open:)
@steventorrestam
I made a small article here with just importing Aviatrix Metrics and adding them to a Dashboard:
https://blog.mihai.tech/2024/dynatrace-monitor-your-aviatrix-environment/
Also have to thanks @Radu for having explained 1-2 things to me to get me unstuck.
Hello does the what is your API endpoint, end with its the env /metrics-api or you using any other endpoint to call and get the metadata back. When i am in my VScode and put my endpoint ABC123.com - 30 High-Impact Business Concepts & Revenue Paths, i am not getting the response showing it pulled that metadata back for the metric definitions.
Good Job @mihaime !
