Hi Steven, my name is Bryan Ashley, and I am the VP of PMM at Aviatrix. While we are still working through additional integration partners, we are thrilled that you want to leverage Dynatrace to expose this additional telemetry and insights. We would be happy to work with you and any Dynatrace representatives to see what we could make work for your organization. Please don’t hesitate to reach out to me and I can connect you to some supporting resources who can work directly with you. My email address is bashley@aviatrix.com.
Hi Bryan -- I am in the Technical Alliance team at Dynatrace and would like to understand more about your solution and will reach out to you via the email you shared above.
I am also with Aviatrix and have a question on this topic…just that unlike Bryan I’m more the reverse engineering all rounder type:)
We expose the metrics in OpenMetrics format.
We can also have a Prometheus installation that imports OpenMetrics from our custom URL.
This raises the next question:)
a) Can I integrate Dynatrace directly with OpenMetrics?
if yes, then do I just write that custom yaml file (plugin definition) and with what metrics it would find? (I looked very superficially at it some minutes ago so excuse any discrepancies, I will read more during my train ride now)
b) Same question for Prometheus
I did find your article that is K8S dedicated and requires also some annotations (not my case)
For a) metrics are exposed by querying an URL like this:
1. The simplest one, Dynatrace provides out-of-the-box support for ingesting metrics from Prometheus exporters in Kubernetes. In this case, you use Prometheus to expose your metrics in the OpenMetrics format, but for that, you need a K8S cluster, and annotations on the pods are a prerequisite.
2. If you don’t have a Kubernetes env, you can create a custom extension V2 using the Prometheus data source, which is native in the Dynatrace extension framework. You can choose to run it on an ActiveGate or a OneAgent :
The Dynatrace Prometheus datasource may indeed support OpenMetrics, but you’ll need to test it to confirm. This compatibility is plausible since Prometheus uses OpenMetrics as its standard for metric exposition, and the Prometheus client library for Python can capture metrics in this format.
If it doesn’t work natively, you could develop a Dynatrace Python extension using the Prometheus client library for Python.
Last dumb question, do you have any examples from 0 to hero type on this topic?
I even tried setting up the Extension in VSCode and I got some errors there so anything like a walkthrough with 1-2 examples would be magic and save me from the initial banging my head against the walls experience.
Was trying to skip through it last time because of lack of time but after watching it e2e today without any disturbance, I can say it did unblock me and I managed to get everything to work (Except the extension simulator but that is probably because I am on a mac).
Hello @mihaime if you happen to make a successful Aviatrix extension. Do you mind sharing your extension with others? I would love to try it out within my company too. We have it on the internal roadmap for design but other efforts are currently in the works in front of it.
I managed to get it to read my metrics so far so did not need the simulator anymore.
Now while watching the Dynatrace Extension 2.0 video in repeat I was wondering if I need the Topology or not as I saw I can create Dashboards on my own (but yeah they do not hold any relational logic in them, true).
Do you happen to have a magic link that would also explain how to define the yaml structure for topology?
So far I reached this one while looking up what the properties defined in the video are:
and then googled a bit..but feel there must be an E2E tutorial that goes through everything in a single article somewhere.
Do you happen to have a magic link?
If not, then I manage, no worries. It does not seem to be rocket science
I just tried too fast to be from 0 to hero in 1 day.
Will do once it’s ready. In fact I am working for Aviatrix but not in the engineering department or in PS.
I wanted to get this one working for a demo and I did miss looking under the hood of things and trying to figure out how they work.
I just need to be more patient and not think that I can get it in just a few hours while also multi-tasking. My bad.
@mihaime do you work for @bashley8 ? I know I have reached out to Brad on email and he introduced me to some associates. We should all look to regroup together to get this going. As this would be nice to have at the end a GA release version to share with all of the Dynatrace Community that uses Aviatrix and DT. Today my team is currently ingesting the API info into Splunk for some base dashboard of Aviatrix performance but i would love to walk away from that and do it all in Dynatrace, since that is my company #1 enterprise monitoring tool.
No but we know each other pretty well I’m far far away..in Europe I asked @bashley8 to put me in contact with you and will probably reach out toward Monday.
Still need to do some experiments but I’m slowly getting the hang of Dynatrace. Quite cool technology, can’t believe I did not spot it earlier.
What I still miss is an E2E tutorial or a logical schema approach with Steps and where/what fits in the puzzle to get the high level overview and then to have the nitty gritty details and different doc sections for each.
(I know what you’re saying with Splunk and API past me played with Splunk and Cisco ACI ingestion of data…though that part was not so well developed or desired by the 2nd vendor)
