I am trying to create the extension to get the metric from the Prometheus exporter.
That is the only solution for monitoring the Pacemaker cluster in Azure, where we are running our critical SAP Systems.
Up until now, I am able to see metrics from one specific endpoint, but I need to get the labels, like below:
# TYPE ha_cluster_pacemaker_nodes gauge
ha_cluster_pacemaker_nodes{node="vmucspscs001",status="dc",type="member"} 0
ha_cluster_pacemaker_nodes{node="vmucspscs001",status="expected_up",type="member"} 1
ha_cluster_pacemaker_nodes{node="vmucspscs001",status="maintenance",type="member"} 0
ha_cluster_pacemaker_nodes{node="vmucspscs001",status="online",type="member"} 1
ha_cluster_pacemaker_nodes{node="vmucspscs001",status="pending",type="member"} 0
