Extract data of MSISDN with multiple IMSI
Hello all ,
i am new for DQL so i am trying to extract data of MSISDN against the IMSI where i have multiple IMSI , so is there any way so  that query take IMSI and extract the MSISDN against those IMSI in one go .
fetch logs,scanLimitGBytes:-1
| filter dt.system.bucket==“engineering” and index == “AB”
| filter Market == “NA”
|filter IMSI==“1800189”
|filter isNotNull(MDN) and MDN != 0
|fields DEG_MDN
output -:
MDN
8634####
Can you please elaborate more on that and provide a sample of the log record?
i am getting msisdn with this query but i have multiple imsi so wants to get msisdn  in one go is it possible ? PFA the snap .
I’m still not sure what you need and, most importantly, how the source data looks like.
Maybe you need to summarize with collectDistinct ?
basically simple thing on behalf of IMSI i am trying to extract MDN , but i have multiple IMSI so how can i check MDN details , it extracted by manual process but when we have IMSI in 1K range then not possible to get MDN against the IMSI.
Logs format -:
Here numericMDN(real numeric MSISDN) due to some compliance i can not upload real logs . logs are pipe separated .
Date |HTTPS|OUT|0|DEG_MDN| IMSI |someAPIName|SessionID| DEG_MDN=numericMDN
to filter by multiple values you can use in() function, like:
|filter in(IMSI, {"1800189", "1800188", "1800187"})
If you want to know which DEG_MDN belong to which IMSI, just leave both fields in output:
|fields DEG_MDN, IMSI
Hello All,
Happy new year , hope you all are doing well . i wants to get result of unique IMSI against the specific API i have this query and getting some result so can you suggest me if any other option to get best results.
| filter dt.system.bucket==“engineering” and index == “db”
| filter SourceDestination==“Device”
| filter Market == “IN”
| filter Direction == “OUT”
| filter TransactionType == “getMSI”
|summarize countDistinct(IMSI)
note -- IMSI is a field here ,that one i wants to get distinct count for the same.
2695384
Hello All,
2695384
Hello All,
2695384
