I am querying the list of hosts in our environment, i would need to also filter by presence of a tag and to see the tag name and value in a column of the resulting table,
the fact is that Business Segment tag can have multiple values, like Sales, IT, Finance, and each hosts has may tags and what i need is to extract the value of the Business Segment tag into a separated column, to see a grid showing only IT, Finance or Sales in a column, after the host name and the host id,
the field tags is an array of multiple tags. You need to use the expand command to expand it and then parse the key value information from the tag itself.
Hello, I believe this is quite old comment but I am new to Dynatrace and was wondering if there are any documentation/guide available to help me understand the parsing command better that was used in the query here, thank you.
