I have this message “Exception org.springframework.web.servlet.resource.NoResourceFoundException”.
I want to find the latest section of this message which is “NoResourceFoundException”.
I prefer to find the text after latest “.” dot.
Can I do this?
Can I do this?
Try use this regex:
Hi @thanawat
you can create a query to return the value after “.”
or create a rule to fetch exact message in the exception after “.”
BR,
Peter
Hi @DynaWiz , @Peter_Youssef
thank for your suggestion. Could you share the link for the solution that you mention?
I mean how to use regex with DQL or example query to get expected value.
