Extracting Bizevents in v2
While you cannot directly specify the exact permission for capturing business events when generating an access token in Dynatrace
Currently, the Dynatrace API only supports retrieving Bizevents via the PUT method, not GET. This means you cannot directly fetch Bizevents using a standard GET request
“Inquire about alternative methods for exporting business events”
yes you can query them through the DQL API
curl -X 'GET' \
  'https://{environmentid}.apps.dynatrace.com/platform/storage/query/v1/query:execute?enrich=metric-metadata' \
  -H 'accept: application/json' \
  -H 'Content-Type: application/json' \
  -d '{
  "query": "fetch bizevents \n| limit 10",
  "maxResultRecords": 10,
  "maxResultBytes": 1000000,
  "fetchTimeoutSeconds": 60,
  "requestTimeoutMilliseconds": 1000,
  "enablePreview": true,
  "defaultSamplingRatio": 1000,
  "defaultScanLimitGbytes": 10
Hello Mark, could you help me, where is this api, I am looking in the swagger but I din´t find it
@carlos_carreno it’s the platform API, not environment API. Basically. https://<environment>.apps.dynatrace.com/platform/swagger-ui/index.html
You can find more information here:
