F5 Monitoring Capability
I’ve noticed a few posts in the community discussing F5 Load Balancer monitoring with either AppMon or Dynatrace Managed… Can someone please explain the current capability of Dynatrace Managed in this area?
A response to a post here (back in February) suggests that Dynatrace Managed agents may theoretically be able to get more visibility into the LB as the agent is installed at an OS level.
https://community.dynatrace.com/spaces/148/uem-open-…
Jacob
We recently released support for f5 load balancers:
Here’s the blog post: https://www.dynatrace.com/news/blog/introducing-the-f5-ltm-activegate-monitoring-plugin/
And the documentation: Extensions — Dynatrace Docs
Mike
Will F5 load balancer be shown in Service Flow?
same question @Mike_L  Is that it can be show in Service Flow?
Not yet, it is currently being worked on.
Hi Mike,
Can F5 Big-IP extension monitor F5 Cloud balancer?
Thanks in advance.
Elena.
Hi Mike,
same question @Mike_L  have any option to monitoring F5 cloud Balancer?
We do not currently. You can go with a product idea or a services engagement or look into building an extension yourself.
Is it possible to show F5 in service flow now? Does F5 show up in proxy chains from service flow?Thx.
