Failed to assign monitoring in MSSQL Extension
HI, this is log given when I have configured a connection for MSSQL extension configuration.
Failed to assign monitoring configuration to ActiveGate. Reason: The monitoring configuration requires ActiveGate version 1.242.0 or later that supports data source sqlServer and belongs to group “default”
It doesn’t make sense to me as the active gate version in our environment is way higher than the required version 1.242.
Has anyone encounter this before?
Error log.pdf (17.2 KB)
active gate.pdf (22.8 KB)
Have you assign a group to ActiveGate?
Best regards
Hi Starhut,
I see that you are missing enabling the appropriate modules on ActiveGate, which are used to run extensions.
You have only enabled modules for:
  • Kubernetes
  • OneAgent routing
  • Rest API
You need two modules more:
  • Extensions 1.0
  • Extensions 2.0
Please follow the documentation: Route OneAgent traffic to Dynatrace, monitor cloud environments and remote technologies using extensions — Dynatrace Docs
Remember that it only works on the Environment ActiveGate.
Radek
Group is assigned by default.
Update of status:
After reminded by Radek, I went through to check the extension of module and found that required extension module was missing in EAG. A correction on Radek, he was looking at the first activegate (containerized AG), instead it should be second active gate (EAG). Nevertheless, module was missing and I have added it back through custom.properties.
After that, error gone and connection was up for the extension.
Hi Radek, I have already configured these extensions and I tried to configure “Activate extension Microsoft SQL Server 2.3.0” But I got this error, could you please assist me with this issue?
