Failed to install secondary node - Dynatrace Managed
We are unable to install the secondary node in DT Managed cluster, if we look on the command in the failed message, DT kept the first cluster IP in the command (192.168.10.78):
“Cannot continue secondary node installation - Failed to send GET request to https://192.168.10.78:8021/api/v1.0/control/serverManagement/operationState , error 13 - connection error: GET request to https://192.168.10.78:8021/api/v1.0/control/serverManagement/operationState  failed, error: [Errno 110] Connection timed out.”
Even if we precise in the UI the new IP (in the web UI IP address) and in the command:
/bin/sh -x managed-installer.sh --seed-auth dt0c01.I2M7JYRW3IHANXEZB.{tokenkey} --cluster-ip 10.161.125.450
Can you help us to find out how we can install the new node, please?
This may be related to a timeout issue I once had installing a Managed node, check out this topic to see if you can use the information: Solved: Re: Installation OneAgent on Managed Cluster Node - Dynatrace Community
You can change timeout value on components, but I think to get the fastest track to solution and installation is opening a support ticket.
Customize installation for Dynatrace Managed | Dynatrace Docs
Hi
I have the same error.
could you solve this error?
Installation in silent mode failed, with status: connected to Mission Control after 3 seconds.
Exit code: 3
Warnings:
It is not recommended to use iptables-nft. Please install nft with firewalld
Errors:
Cannot continue secondary node installation - Failed to send GET request to https://10.55.20.69:8021/api/v1.0/control/serverManagement/operationState, error 13 - connection error: GET request to https://10.55.20.69:8021/api/v1.0/control/serverManagement/operationState  failed, error: [Errno 111] Connection refused.
