hello,Is there any way in DQL to return a constant value? In SQL it would be something like
select 'hello world' from dual
Best,
Sini
Best,
Sini
Hi Sinisa, the data command allows you to generate sample data during query runtime. You could do something like this:
data (record(data = "hello world"))
