I am developing an app for a user, using useDQL and an DatatablesV2 control. I am trying to create filters on the DatatableV2 using filtering controls (FilterBar), but none of the examples use DQL as a source and I cannot get filtering to work. Does Dynatrace have an example app that filters a DatatableV2 using data from useDQL (UseDqlResult/ResultRecord) type?
Hey there,
You are right. None of the existing examples we have uses data from a DQL query as a base.
Here’s a minimal example that does pretty much the same as FilterBar | Dynatrace Developer but uses data from a DQL query as a base.
It fetches logs via DQL, shows them in a DataTableV2, and allows simple filtering of the log level via a TextInput in a FilterBar.
import React from 'react';
import { Flex } from '@dynatrace/strato-components/layouts';
import { DataTableV2 } from '@dynatrace/strato-components-preview/tables';
import { useFilteredData } from '@dynatrace/strato-components-preview/tables';
import { FilterBar } from '@dynatrace/strato-components-preview/filters';
import { TextInput } from '@dynatrace/strato-components-preview/forms';
import { useDql } from '@dynatrace-sdk/react-hooks';
export const App = () => {
const queryString =
'fetch logs | fields timestamp, loglevel, content | sort timestamp desc | limit 100';
const { data } = useDql({ query: queryString });
function filterFn(filters, entry) {
const filterValue = filters.loglevel?.value ?? '';
const loglevelValue =
typeof entry.loglevel === 'string' ? entry.loglevel : '';
return (
!filterValue ||
loglevelValue.toLowerCase().includes(filterValue.toLowerCase())
const records = React.useMemo(() => data?.records ?? [], [data?.records]);
const { onChange, filteredData } = useFilteredData(records, filterFn);
return (
<Flex flexDirection="column" padding={32}>
<FilterBar onFilterChange={onChange}>
<FilterBar.Item name="loglevel" label="Log Level">
<TextInput />
</FilterBar.Item>
</FilterBar>
<DataTableV2
columns={[
{ id: 'timestamp', header: 'Timestamp', accessor: 'timestamp' },
{ id: 'loglevel', header: 'Log Level', accessor: 'loglevel' },
header: 'Content',
accessor: 'content',
width: '2fr',
data={filteredData}
fullWidth
</Flex>
I hope that helps!
