Filtering by custom errors in Mobile Dashboard
We are sending errors using
Dynatrace.reportError(...)
and I cannot find an easy way to find these errors, I haven’t found a way to filter user sessions by custom errors in the Mobile Dashboard
Is there a way to filter by the errors we are sending via Dynatrace.reportError() in the Mobile Dashboard?
You might be able to filter from user sessions
If you are particularly looking for custom errors for mobile I think they cant be reported for Mobile apps at least from what I see below ( I could be wrong)
Hi, thanks for your reply.
What I was specifically referring to was Reported error and Custom Actions
In regards to the Reported error:
Dynatrace.reportError(xyz, xyzException)
That’s what we have, but the filter in the screenshot you shared isn’t picking it up.
I have found however that clicking on this will show the errors:
For now this satisfies the requirement I had.
In regards to filtering by Custom Actions, I’ll work on it a little more.
Actions: Instrumentation via OneAgent SDK for Android in RUM Classic — Dynatrace Docs
