Find transaction/volume per hour for any application
Hi ,
I am  looking for a way to showcase volume per hour for any application and showcase it on dashboard based on selected timeframe in timeframe selector. .Please suggest best way to do it.
Heramb Sawant
If by application you mean RUM (Web, mobile, custom), the best way to do it is using USQL, something like “SELECT count(userSessionId), useraction.application FROM usersession GROUP BY useraction.application” Custom queries, segmentation, and aggregation of session data in RUM Classic — Dynatrace Docs
Or you can also do it using the bultin metrics, such as builtin:apps.web.activeUsersEst
If you are looking for backend applications, then it is better to use a builtin metric, such as builtin:service.requestCount.server
How I can find this volume( transactions) per hour and display on dashboard?
is this possible using grail as well ??
Heramb Sawant
Unfortunately, application data is not yet in grail, Built-in Metrics on Grail — Dynatrace Docs
Hi @heramb_sawant , did you find any workaround to show application traffic volume in a table or dashboard? If yes, can you share it with us as we have similar kind of requirement and I am stuck.
@_raj_ RUM in Grail is not yet GA (will be GA likely in December or January). Then you can add RUM metrics from Grail on the Gen3 dashboard.
From RUM Classic, you can add metrics by utilizing code tile and API. Check for example this video -
