Is anyone doing cloud cost optimization / FinOps on GCP (or other cloud providers) ?
One of my customer runs on GCP wants to right-size their Kubernetes workloads (and other GCP services…). The ideal output would look like:
Current:
Has anyone built something like this ? dashboard, notebook, workflow ?
And if yes, how did you do it ?
Thanks for your help
Hi @agonzalez
Dynatrace actually has built-in capabilities for this exact use case:Dynatrace provides workload resource optimization out of the box. Go to Kubernetes → Workloads — it shows CPU/Memory requests, limits, and actual usage per workload with right-sizing recommendations.
Optimize workload resource usage with Kubernetes app and Notebooks — Dynatrace Docs
For the exact output format you described, use Notebooks with DQL . like:
fetch dt.entity.cloud_application
| fieldsAdd requests_cpu = …, limits_cpu = …, actual_cpu = …
| fieldsAdd recommended_cpu = …
Cost & Carbon Optimization App
Dynatrace has a dedicated Cost & Carbon Optimization app that calculates IT cost based on public cloud price lists (including GCP) at host level.
Cost & Carbon Optimization — Dynatrace Docs
Sujit
