For creating Funnel chart
can we create Funnel chart using metrics? If it is not possible with metrics, can we ingest custom User sessions through API. So that, I can create a Funnel chart of user journey with some preferred values?
Hi @saisandeep,
AFAIK it is not possible. Funnel can be done only form USQL.
Best regards,
Mizső
Hi Mizso,
Can we add custom user session?
Hi @saisandeep
Yes, if it have Custom Action configured, you will be able to use it in creating USQL based views.
Radek
Hi @Mizső , @radek_jasinski ,
Iam trying to create a Funnel chart of user journey and for that we need user sessions. So, we are not monitoring any application here. I just want to upload custom user session. Can we upload user session using APIs or is there any other way to create a user session or demo funnel chart of user journey?
No, custom action is assigned to the application. There is no way to send otherwise without the application.
