Hi, some guidance could be helpful. I have deployed the last version of the extension, 1.012 and I’m getting the following metrics:
Metrics
Device
Connectivity
Ping Availability
Ping RTT
- CPU Usage
- Memory Usage
- Disk Usage
- Disk Log Rate
- Sessions
Interface
- Bytes In
- Bytes Out
- Errors In
- Errors Out
Tunnel
- Tunnel - Bytes In
- Tunnel - Bytes Out
- Tunnel Proxy - Bytes In
- Tunnel Proxy - Bytes Out
But I’am not able to get data for the rest of the metrics.
The Fortigate on AWS has been configured in the following way:
Rest API user profile on Fortigate:
The Fortigate firmware is v7.0.5 build0304 (GA).
What I’m missing on this config?
hi, did you reach a solution to your problem? i’m facing the same issue, only the ping metric is showing, the other metrics are not
Hi Daniel,
I have the same problem with extension 1.017. Did you get a solution?
Juan
Mike_L
5
Please create a support case.
jegron
7
New version 1.018 extension is released.
Does it fix your issue ?
This following metrics are working because generated by a simple ping :
- Connectivity
- Ping Availability
- Ping RTT
I have the same issue regarding other metrics. After some troubleshooting issue is related to post login banner which impact API Call.
KB : https://community.fortinet.com/t5/FortiGate/Technical-Tip-Unable-to-get-information-via-REST-API-using/ta-p/254723
