frequent issue lifetime
Am I correct assuming that a frequent detected issue mever disapeers by itself? Only a reset of the baseline or turning it off the feature will remove the status?
KR Henk
Hello @henk_stobbe,
yes in some cases, as long as the severity and duration didn’t increase from previous alerts, new problems will not be detected on the Problems page.
as per what is mentioned in the documentation “Problems that are less severe and have a shorter duration than previous alerts are considered to be frequent issues and so alerts are suppressed for these.”
You will find all the details here:
