GCP functions (Node.js) integration with Dynatrace
Hello experts,
I’m learning how to integrate GCP function traces with Dynatrace documentation for Node.js:
1.Set up OpenTelemetry monitoring for Google Cloud Functions — Dynatrace Docs
2. Integrate on Google Cloud Functions Node.js — Dynatrace Docs
Sadly, I can’t get the traces on Dynatrace’s side using the doc samples for the code:
index.js (where helloHttp is my entry function):
const functions = require('@google-cloud/functions-framework');
const { Resource } = require('@opentelemetry/resources');
const { NodeTracerProvider } = require('@opentelemetry/sdk-trace-node');
const { SemanticResourceAttributes } = require('@opentelemetry/semantic-conventions');
const { DtSpanExporter, DtSpanProcessor, DtTextMapPropagator, DtSampler } = require('@dynatrace/opentelemetry-gcf');
const processor = new DtSpanProcessor(new DtSpanExporter());
const provider = new NodeTracerProvider({
  resource: new Resource({
   "my.resource.attribute": "My Resource",
  sampler: new DtSampler(),
  // for @opentelemetry/sdk-trace-node versions lower than 1.29.0 use `provider.addSpanProcessor(processor)` instead
  spanProcessors: [processor]
  // ...other configurations
provider.register({
  propagator: new DtTextMapPropagator(),
// ...tracing initialization code
const { startActiveHttpSpan, endHttpSpanAndFlush } = require('@dynatrace/opentelemetry-gcf');
async function handler(req, res) {
  await startActiveHttpSpan(req, async (span) => {
    let error;
    try {
      // do something
      console.log("Hello Console...")
    } catch (e) {
      error = e;
    // status should be set before span ends
    res.status(error != null ? 500 : 200);
     * Span must be ended and flushed before handler sends response.
     * This limitiation comes from GCF, for details see:
     * https://cloud.google.com/functions/docs/concepts/nodejs-runtime#signal-termination
    await endHttpSpanAndFlush(span, res, error);
    res.send("hello world!");
functions.http('helloHttp', (req, res) => {
    handler(req,res);
I ran the same test with a Python function, and it worked without issues, which makes me think my code has an issue.
Thank you in advance for any comment or recommendation; it is well appreciated.
