Hello Team,
I am trying to setup active gate on my local Ubuntu server. I tried multiple times on other server as well however every time i install Active Gate i Get the below error:
2026-04-22 08:40:59 UTC Cleaning autobackup... 2026-04-22 08:40:59 UTC Waiting for modules download. Timeout in 15 minutes. 2026-04-22 08:41:59 UTC Waiting for modules download. Timeout in 14 minutes. 2026-04-22 08:42:59 UTC Waiting for modules download. Timeout in 13 minutes. 2026-04-22 08:43:59 UTC Waiting for modules download. Timeout in 12 minutes. 2026-04-22 08:44:34 UTC Capability download status is: RemotePluginModule, ERROR, Autoupdate: Installer file download failed with exception: com.compuware.apm.collector.shared.autoupdate.AutoUpdateException: Error receiving a chunk: Error response received: COMMUNICATION_ERROR, reason=java.net.SocketException: Socket closed source=SERVER 8 2026-04-22 08:44:34 UTC Stopping Dynatrace Gateway... 2026-04-22 08:44:48 UTC 2026-04-22 08:44:48 UTC -------------------------------------------------------------- 2026-04-22 08:44:48 UTC 2026-04-22 08:44:48 UTC The following problem(s) encountered: 2026-04-22 08:44:48 UTC ERROR: Download of the following Dynatrace ActiveGate capabilities has failed: RemotePluginModule 2026-04-22 08:44:48 UTC 2026-04-22 08:44:50 UTC To re-try the installation, first uninstall Dynatrace ActiveGate as user 'root', using command '/opt/dynatrace/gateway/uninstall.sh', then repeat the installation. 2026-04-22 08:44:50 UTC To gather diagnostic data for troubleshooting, see: https://dt-url.net/6z038tm 2026-04-22 08:44:50 UTC Installation failed. 2026-04-22 08:44:50 UTC Log preserved in /var/log/dynatrace/gateway/dynatracegateway-install_20260422-140937.log |
Can someone please help to fix this. Its not in my one enviroment I get this error in other free trial env. as well.
Were you able to download ActiveGate shell script from tenant? It is important you are using latest shell script version and it is executed with root privileges.
Best regards
Yes, I have downloaded the ActiveGate from the tenant. Just facing issue while installing.
Hello guys,
So this usually points to a network/proxy/TLS issue on the ActiveGate host, not the Dynatrace environment itself, especially since it happens in multiple environments.
That means the server starts downloading the capability, but the HTTPS connection gets interrupted.
I’d suggest checking these first on the Ubuntu server:
- Outbound access to Dynatrace on port 443
Make sure the server can reach the exact Dynatrace endpoints shown in the ActiveGate install page.
- Proxy / SSL inspection
If your network uses a proxy or TLS inspection, ActiveGate may need explicit proxy configuration and the proxy/root CA imported.
- Clean reinstall
Uninstall ActiveGate, clear the package/cache folders, then reinstall.
- Logs
Check /var/log/dynatrace/gateway/ (or somewhere, not sure) for handshake, certificate, proxy, or connection reset errors.
Since it fails with RemotePluginModule download, I would focus on firewall/proxy/certificate trust first.
Checked below:
- Outbound access to Dynatrace on port 443:
network is OK
- proxy / SSL inspection check
env | grep -i proxyGot nothing.
- Checked SSL / certificate issues
Verify return code: 0 (ok)
- Clean reinstall of ActiveGate
sudo /opt/dynatrace/gateway/uninstall.sh
sudo rm -rf /opt/dynatrace/gateway
sudo rm -rf /var/lib/dynatrace/gateway
Reinstalled. But still:
2026-04-22 09:29:58 UTC Cleaning autobackup…
2026-04-22 09:29:58 UTC Waiting for modules download. Timeout in 15 minutes.
2026-04-22 09:30:58 UTC Waiting for modules download. Timeout in 14 minutes.
2026-04-22 09:31:58 UTC Waiting for modules download. Timeout in 13 minutes.
2026-04-22 09:32:58 UTC Waiting for modules download. Timeout in 12 minutes.
2026-04-22 09:33:58 UTC Waiting for modules download. Timeout in 11 minutes.
2026-04-22 09:34:58 UTC Waiting for modules download. Timeout in 10 minutes.
2026-04-22 09:35:58 UTC Waiting for modules download. Timeout in 9 minutes.
2026-04-22 09:36:58 UTC Waiting for modules download. Timeout in 8 minutes.
2026-04-22 09:37:58 UTC Waiting for modules download. Timeout in 7 minutes.
You should also have ownloaded capability packages in /var/lib/dynatrace/packages and the Remote Plugin Module runtime/cache in /var/lib/dynatrace/remotepluginmodule, so removing only /opt/dynatrace/gateway and /var/lib/dynatrace/gateway can still leave stale capability artifacts behind.
Maybe try to remove them first, and we also expects meaningful free space in those areas: the packages directory is sized for 500 MB, the remote plugin runtime area for 2 GB, and the temp area for 4 GB.
I waited for the module to download. Now is Working.
Thanks for the help.
