Generate Problem notification report using DQL
Is there a way to generate list of problem notifications using DQL?
Srikanth S
@SrikanthSamraj When you say “problem notifications”, are you referring to list of active/close problems  or list problems that were notified as email or sms etc., ?
@p_devulapalli - I’m not referring to problems here instead the list of notifications created in settings → integrations → problem notifications.
@SrikanthSamraj Not sure you would be able to query the problem notifications using DQL, however you should be able to extract the details via API if it helps.
Thanks @p_devulapalli . I’m aware of the API part, curious to figure out if the same can be achieved via DQL.
