Hello Community,
I am currently exploring the workflow capabilities for Analyze with Davis. I’ve created a simple workflow that runs every day at 05:00 AM to check for specific errors in a particular log. If the error count is 1, it should create a problem. I added an action ‘Analyze with Davis’ included my dql and set the static threshould, workflow runs successfully not getting any problem/events out of this ? Does the ‘Analyze with Davis’ action in a workflow automatically create a problem like the Anomaly Detection app, or do we need to use JavaScript to create the problem ?
Hi Akhil,
Yes, you need to push the problem using a separate task. For instance, I have two executions—one without anomalies and another where the static threshold condition was exceeded.
Use values from the result JSON to define a condition in the next task. Based on that, I either send an alert to Slack or push a problem to the Problems API.
You’ll notice that the execution with an issue includes additional fields like raisedAlerts, numberOfViolations, etc., which help identify and handle the problem.
Thanks @Emm4nuel ,
I’ve added a JavaScript action, but unfortunately it’s not working. My JavaScript knowledge is a bit limited. I’ve attached the workflow JSON ,any chance to have look?
wf_check_logs_3dc31eb5-261a-4d7c-b014-6e7918698f7c.json (4.46 KB)
You have a structure mistake in your output variable, I fixed it: Try with this code:
Please, let me know if it works for you.
import { eventsClient, EventIngestEventType } from "@dynatrace-sdk/client-classic-environment-v2";
import { execution } from "@dynatrace-sdk/automation-utils";
export default async function ({ executionId }) {
// Step 1: Get workflow execution result
const exe = await execution(executionId);
const checkResult = await exe.result("check_logs");
// Step 2: Inspect output structure
// I made the change here!
const output = checkResult?.result?.output[0];
const dimensions = output?.dimensions || [];
console.log("Full dimensions:", JSON.stringify(dimensions, null, 2));
// Step 3: Extract potentialAlerts from dimensions
const potentialAlertDim = dimensions.find(dim => dim.key === "potentialAlerts");
console.log("Raw potentialAlertDim:", potentialAlertDim);
const potentialAlerts = parseInt((potentialAlertDim?.value || "0").trim(), 10);
console.log("Parsed potentialAlerts:", potentialAlerts);
// Step 4: If alert count > 0, send a custom event
if (potentialAlerts > 0) {
const hostDimension = dimensions.find(dim => dim.key === "dt.entity.host");
const hostId = hostDimension?.value;
if (hostId) {
console.log(`Raising event on host: ${hostId}`);
await eventsClient.createEvent({
body: {
eventType: EventIngestEventType.CustomAnnotation,
title: "⚠️ Predicted Disk Capacity Alert",
description: "Disk issue detected based on timeseries analysis",
entitySelector: `type(HOST),entityId("${hostId}")`,
properties: {
"dt.entity.host": hostId,
severity: "warning"
source: "workflow-automation"
} else {
console.log("Host ID not found in dimensions.");
} else {
console.log("No potential alerts found.");
Thank you so much @Emm4nuel , it worked like a charm.
