Get distributed trace and problem backtrace via API
Is it possible to fetch failure or problem or service trace (distributed or backtrace)?
You can’t fetch traces or transactions using APIs. but to get closer, you can use monitored entities API and problems API to get some of the required information.
In case you are using SaaS with grail, you can pull them using DQL.
Islam
