Hi community,
i would like to send problem information to our to ticket system, to inform our customer. Important for this worklfow is the information, which entity is reporting. We send the information to the teams in dependency of the entity.
Unfortunatly the object in the worklfow “Davis problem trigger” only has the information of the affected entity as Id like this [“HOST-B800B96861849859”]. For this reason, i can’t send a http-request to the entity, because it isn’t the matching https format. (I know the parameter “affected entity id” is not the best, but first i would like to work with that.)
So i have to customize the information in a java script object.
Placeholder like {{…}} are not working in Java script. So we tried this script to get the informatione from the object “Davis problem trigger”
import { execution } from ‘@dynatrace-sdk/automation-utils’;
const previousTaskName = 'Davis problem trigger
export default async function ({ execution_id })
var exe = await execution(execution_id);
console.log(execution_id);
var task_result = await exe.result(previousTaskName);
console.log(task_result);
var records = task_result[‘records’];
console.log(records);
The output from this script says, that there is no matching object with this id. I checked this information, and saw, that die Id from the object “Davis problem trigger” matched with the id, which ist not found from the script.
Now I have no idea what to do next. I didn’t found any solutions in the documentation and Community.
Can you help me? Are my thoughts to get this information to complicated?
I`m looking forward to your answers!
Regards
Marius
